Author Topic: 1.8t Air vents not illuminating!??  (Read 1971 times)
Offline Chris#101
« on: 29 September 2011, 21:16 »
How do, New to the forum so appologies in advance if this is in the wrong place :undecided:
I did have a quick search but kept coming up with the bora vent info!
Noticed that My air vents dont illuminate on my 03 Auq 180t!! Are they suppose even suppose too!?
my friends '00 aum 150 illuminate which got me thinking!
Any help or suggestions would be great!
thanks
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Rhyso
Re: 1.8t Air vents not illuminating!??
« Reply #1 on: 29 September 2011, 21:48 »
No they don't unless you fit the bora vents
You should notice that your mate's vents are a different design unless he has retro fitted the leds into his standard vents
You could ask him mind  :tongue:
Offline Toby
  • Car - less
« Reply #3 on: 30 September 2011, 08:33 »
Here bora vents
Or r32 or anni
Currently down under
paul james
« Reply #4 on: 30 September 2011, 08:34 »
rhyso is right if they dont shut their not bora/r32 vents
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 30 September 2011, 13:46 »
yes, if they don't close flush they are standard versions
Offline Chris#101
« Reply #6 on: 30 September 2011, 15:09 »
His arent the bora/r32 self shutting ones thought  :huh:
Brought the car like it so I take it someone has fitted leds into them!?
and they deffinitely dont come illuminated on standard gti vents?
« Reply #7 on: 30 September 2011, 15:40 »
Sounds like it tbh. :smiley:
