Author Topic: Front brake caliper bolt head rounded off!  (Read 5203 times)
Offline Mann
« on: 29 September 2011, 17:31 »
As above mine rouned off to hell, now what I gonna do? Drill these out or other way to take them off?
Also where can I get new ones as other nearly rounded too!  :undecided:
Last one is what I was stuck with!
Seem nearly rouned, where I get new one?
Offline Sam
  • Sam I am
Re: Front brake caliper bolt head rounded off!
« Reply #1 on: 29 September 2011, 17:34 »
Dealers  :smiley:
Offline JMallows
« Reply #2 on: 29 September 2011, 19:22 »
I had this recently. Right pain to get off :( I snapped the bolt too... which helped, as then i just cut a notch in the end, and used a screwdriver.
Only replaced the bolts two years before with ones from the dealership, which was easy enough at the time... went back in this time and they couldnt find any bolts to fit apparantly. He did come out with some from a MK4 which looked identical to me, same pitch, length etc, but he said, different part number - wont fit. I walked away and went to my local bolt shop, and they found the same bolts and charged i think 60p for all four?
Gave them a lick of copper slip grease this time too, should hopefully last more than two years!
A clever person solves a problem. A wise person avoids it.
Offline Mr Blue
« Reply #3 on: 29 September 2011, 19:33 »
what i usualy end up doing:
cut the rubber bits,
heat up the bolt with a blow torch,
smack in a splined torx bit into the hole, or a socket over the whole bolt.
brute force it out.
or get a mole grip on the head.
Offline molegti
« Reply #4 on: 30 September 2011, 10:04 »
I used Irwin Bolt grippers, then replaced the bolts.
Offline pigbladder
« Reply #5 on: 30 September 2011, 10:11 »
make double sure the replacements are high tensile , most diy shop ones wont be
Offline Mann
« Reply #6 on: 30 September 2011, 14:24 »
Thanks all of you it was helpful, I dont think dealer sell them anymore. Nut n bolt shop I will look on google if there one near my area.
High tensile metal, yes I will remember that thanks. If I tear off rubber cover is there replacement too?  :embarassed:
"Irwin Bolt grippers" I check shops online, think might give a try but not just for caliper bolts, can be any kind of bolts  :wink:
Offline molegti
« Reply #7 on: 02 October 2011, 18:52 »
I replaced mine but they came as part of a kit from Bigg Red. Irwin Bolt grippers can be had from machine mart.
Offline tomp
« Reply #8 on: 02 October 2011, 22:57 »
From memory, a 12mm socket hammers on perfectly, can be tightened up again after too
Offline Cory
« Reply #9 on: 05 October 2011, 17:29 »
i spent ages f*cking round with one first time it happened, but second time i just pulled the rubber off, filed two sides of the rounded head then got a monkey wrench on it, took about 20 mins
got new bolts from dealers about a month ago, dont stock them, took about 3 days to order in
