Author Topic: car fires on 3 cylinders when cold  (Read 2291 times)
Offline MaXXeH
  • Golf MK5 GTI
« on: 28 September 2011, 19:34 »
Well i rebuilt this old girl and i have this problem. i have replaced the spark plugs coil packs and ignition amp and i still does it when cold any ideas
Offline stevelfc
Re: car fires on 3 cylinders when cold
« Reply #1 on: 28 September 2011, 20:33 »
coil pack wireing lume  ?
Offline james2
  • No scammers please.
« Reply #2 on: 28 September 2011, 21:10 »
i bet its not a AGU ,prob air pump thing used for cold start.Dont know much about them, sort of a choke, i bet u have all 4 sparks when cold start. ?  :smiley:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline houston
« Reply #3 on: 28 September 2011, 21:15 »
what did you rebuild? use oversized pistons?
could be a sticky ring, pour a bit red ex into the cylinders.
Offline richw911
« Reply #4 on: 28 September 2011, 21:23 »
Bet it is  :wink:
Offline james2
« Reply #5 on: 28 September 2011, 21:37 »
i had this problem on my ford feista xr2i,after rebuild ,it would run fine until hot: ie: if i turn it off and tryed starting it, it wouldnt turn over seized until it cooled down.It did my head in,i tryed frashing the hell out of it to wear them down.Sorted in the end ,took ages ,maybe i did the big ends up to much.God know. :grin:
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #6 on: 28 September 2011, 22:37 »
Could have the dreaded 00575 code. You had it scanned? You checked for split pipes?
Offline MaXXeH
  • Golf MK5 GTI
« Reply #7 on: 28 September 2011, 23:25 »
well it has an AGU bottom end with a BFB head :rolleyes: The VVT solinoed is not connected so should not create any problems.
It runs fine once warm.
only fault is
1 Fault Found:
17953 - Throttle Valve Controller: Malfunction
            P1545 - 35-00 - -
Readiness: N/A
It also has a AGU inlet manifold on a small port head,  I have got a tapered gasket so that sorted that problem.
Offline MaXXeH
  • Golf MK5 GTI
« Reply #8 on: 29 September 2011, 19:05 »
gave the TB a clean runs alot better but still playing up   :sad:  anyone?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 29 September 2011, 20:27 »
might run better if it wasn't such a thrown together engine lol :laugh:
