Golf mk4
Wazzzer
Recon Brakes
Topic: Recon Brakes (Read 922 times)
Dewey
Mk4 1.8t 150 AGU (R-Tech Stage 1 190)
Recon Brakes
28 September 2011, 16:40 »
Im going to be reconditioning my brake calipers, Where is the best place to get the seals etc from? Iv also been told that its better to wait till after the powder coating before removing the old seals, it makes sense but is it the best option?
So Far - R-tech Stage 1 Re-Map 190hp 225ftlbs, Forge 007P DV, Forge Silicone TIP, Pipercross Panel Filter, Powdercoated Anthracite Montreal IIs, Custom Cat Back. Shopping List - Coilovers, Hubcentric Spacers, Front and Rear ARB, Big Brake Set-Up...
james2
No scammers please.
Re: Recon Brakes
28 September 2011, 21:29 »
any good shop (langles).I got my dad to fit mine bad mistake couldnt bleed the brake i pressed so hard, with the bleed nipple open the bloody seal that goes around the piston poped out the bleed nipple.lol it went flying .He must of pinched it and it blocked the bleed hole,until it poped out. :embarassed:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Wayne
Sir Postalot
Re: Recon Brakes
29 September 2011, 00:03 »
Could work out cheaper and easier to get new calipers.
shedpainter
Re: Recon Brakes
30 September 2011, 04:50 »
I've used these people in the past:
www.biggred.co.uk
Golf mk4
Wazzzer
Recon Brakes
