Author Topic: HELP! 1999 1.8turbo to a 2002 AUM 1.8turbo????  (Read 1593 times)
karls3abo
« on: 26 September 2011, 20:01 »
hi there.
previously i had my pride and joy 1999 v plate 1.8t it had the cable type throttle on the turbo and went pretty nice, all round was a really good condition car.
sadly a recovery lorry rear ended me about a month ago due to him being on his phone grrr. i then looked for another mk4 golf so i could swap the coilover kit and alloys across to save me some monies buying new ones. i found a really nice mk4 2002 AUM coded engine for £1400 Bargain in my opinion! my old one cost me £2100! and it is also much better looking body work wise then the old one which i thought would be hard to find!
been reading though and what i can gather my new mk4 should have 180bph?? as apposed to my old one which had 150bph? and also on my new one is the turbo the ko3s?
the main reason i am pondering is because my new mk4 doesnt seem to go as fast as the old 1999 one? it also has a different diverter valve? (this one being a bosch) is that standard?
and also i have noticed a hissing noise with this one when accelerating could this be a boost leak? it sounds like a constant blow off noise at the end of the gear change. i have just bought new turbo hoses and a new intake hose to maybe see if there was a leak?
any thoughts? and am i right in any of this lol..
thanks
Offline barrym381
Re: HELP! 1999 1.8turbo to a 2002 AUM 1.8turbo????
« Reply #1 on: 26 September 2011, 20:03 »
if your cars an aum wont be 180bhp unless its been mapped its the auq thats 180bhp
Offline daz veedub
  • Operation 1.8t bolf
« Reply #2 on: 26 September 2011, 20:03 »
bosch come standerd
and the blow off (tssssssh) noise is wastegate noise its normal
« Reply #3 on: 26 September 2011, 20:04 »
Nope Aum is 150bhp same as your old one, 180bhp is AUQ same as mine, some noise from the dv is normal.
Might be best to get it scanned for codes and see what is what.
If you stuck I am not far from you so could scan it if you wish.
Offline richw911
« Reply #4 on: 26 September 2011, 20:06 »
AUM has k03s turbo and is 150 bhp in standard form - it will remap bettet than your old AGu with the k03 turbo.
Sounds like the standard recirculating valve may be broken  :undecided:
karls3abo
« Reply #5 on: 26 September 2011, 20:06 »
ahhhh i see!
that's cool i was just worrying that there should be a difference but if they are both or were both 150bhp then not to worry. will replace hosing anyways to make sure there are no leaks,
and thanks where bouts are you in relation from minehead??
Offline richw911
« Reply #7 on: 26 September 2011, 20:08 »
It should be a k03s
Offline mcgee9t2
« Reply #8 on: 26 September 2011, 20:21 »
i belive aum are only 150 bhp. but could be wrong
not sure if it has the k03 or k03s.
could be a boost leek. had it scanned to see if theres any codes which could tell you why its holding back?
*oops beat to all three of my points by everyone cause i forgot to press the post button about 20 mins ago :D*
