Author Topic: fao R-TECH  (Read 2849 times)
Offline Tazzy
fao R-TECH
« on: 26 September 2011, 17:15 »
hi guys, a while back i bought a new ECU for my 1.8 20v mk4 non-T, my mate and i suspect its the ecu that is the cause of the problems ive been having, well with this new ecu, weve fitted it, but my mates vagcom cant over ride the immob, so we can start the car, but then it just cuts out, its the exact replacement ecu
apparently, we need to delete some code to get past the immob?!? is it possible for you guys to have a better look and get the new ecu working?
my current issue is that it wont rev past 4500revs, however when the engine gets to running temp, this reduces to 4k revs
cheers
« Last Edit: 21 October 2011, 14:05 by Tazzy »
If It Comes Off, Modify It!
Offline MaXXeH
  • Golf MK5 GTI
Re: fao R-TECH
« Reply #1 on: 26 September 2011, 18:21 »
you just need to match the SKC from your new ecu to your instrument cluster.
do you know the skc?
Offline Tazzy
Re: fao R-TECH
« Reply #2 on: 26 September 2011, 18:54 »
whats the skc?  :huh:
Offline JC
  • Back in the North.
Re: fao R-TECH
« Reply #3 on: 26 September 2011, 19:00 »
that will be a no then  :grin:
Offline tech1889
  • Mk2 GTI FTW !!
Re: fao R-TECH
« Reply #4 on: 26 September 2011, 19:04 »
Offline topher
  • Administrator
  • fully functioning
Re: fao R-TECH
« Reply #5 on: 26 September 2011, 19:44 »
if its a 20v NA it should be immo2 so you won't need the skc. Takes 10 seconds with vagcom, guide is on the rosstech site.
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: fao R-TECH
« Reply #6 on: 26 September 2011, 21:11 »
hi guys, a while back i bought a new ECU for my1.8 20v mk4 non-T, my mate and i suspect its the ecu that is the cause of the problems ive been having, well with this new ecu, weve fitted it, but my mates vagcom cant over ride the immob, so we can start the car, but then it just cuts out, its the exact replacement ecu
apparently, we need to delete some code to get past the immob?!? is it possible for you guys to have better look and get the new ecu working?
cheers
As Chris said its a 2 min job via VCDS to set the immo adaptions, and he is only down the road from you.. :wink:
With your old ecu did you get ant fault codes?
 01455 617233
Offline Tazzy
Re: fao R-TECH
« Reply #7 on: 27 September 2011, 15:09 »
yes, constant fault codes, we cleared it last time (a few weeks ago) but since then, about 9 codes popped up, couldnt tell you what they were though, my mate recleared it
my mate obviously hasnt done something right?!?
Offline Tazzy
Re: fao R-TECH
« Reply #8 on: 29 September 2011, 16:47 »
can anyone help as i need this running by sunday
thanks
