Author Topic: Better Brakes for my 1.8GTI  (Read 1790 times)
karls3abo
« on: 26 September 2011, 17:08 »
as i'm due to change all my disks and pads for new ones in the next month or so i was just wondering if there was any alternative brake kits that would fit? maybe using Audi TT setups? or something similar,would this work?? just thought might as well do this upgrade now rather then paying out more in the longrun.
thanks
Offline km
Re: Better Brakes for my 1.8GTI
« Reply #1 on: 26 September 2011, 17:11 »
http://www.golfgtiforum.co.uk/index.php?topic=87778.0
take a read, just need to buy carriers and obviously the pads and discs. :smiley:
Offline barrym381
Offline km
« Reply #4 on: 26 September 2011, 20:06 »
Just switch to the 312mm set up but you will need 16" or bigger wheels.
karls3abo
« Reply #5 on: 26 September 2011, 20:11 »
thats good to know! probs will do this in the next month or so then, and ye i got some nice 18"ers  :wink:
Offline rockmonkey69
« Reply #6 on: 26 September 2011, 23:01 »
« Reply #7 on: 27 September 2011, 20:53 »
Im afraid in my case, it's rather that it's better full stop!
I have tried 288mm as standard, was awful didn't survive a single track day
996 rear - absolutely rubbish - whilst they have 4 piston calipers the overall surface area of the pistons are less than that of an r32 setup!
312mm with ds2500 - rubbish for track use absolutely not worth trying but didn't fade as quickly as standard
lcr setup with ds2500 - worked better but heat retention was too great, two piece disk is a must
current two piece setup from NEX - ideal for under $2000 mark
All of the above setups were tried and tested on the mk4 weighing the same (1100kg with fuel +/-10kg weighing bridge)
With the same brand new servo, master cylinder and HEL braided brake lines front and rear
Castrol SRF racing brake fluid
I found that my current setup to be impossible to warp or crack thus far, the two piece design allow rapid expansion of disk without distorting.
The same two piece setup means it is far lighter in weight than counterpart single piece disks of the same size
Heat retention properties are not as bad as the full on track setup so these heat up nicely and can be used on road
Cooling is just right, the 28mm veins help dissipate nicely
The pad material provides excellent braking from cold whilst still maintaining a nice operating temperature range
The large 4 pot provides the clamping force that just inspired confidence for late braking
The small fluid galleries in the caliper means there's a solid pedal without much pedal travel unlike other big brake setups which is ideal for the servo size of the mk4
I have had a few big brake setups before, well not big technically, but bigger than standard and will say that these are far superior to the lcr setup.
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #8 on: 27 September 2011, 21:11 »
you have to be careful with some aftermarket 4 pot setups or 6 pot setups aswell, as some are like wilwoods and are prone to pistons seizing/sticking as the dust seals arent brilliant and dust gets in to the piston chambers and scores the pistons, over time mixed with heat will mean a new set of pistons are needed along with a rebuild.
If you want something for road use then the LCR brake setup is a good upgrade, used with a good pad will be loads better than standard. As above with the porsche brakes however they are still a good upgrade over standard brake pedal will have a different feel.
312mm Anni upgrade is a good upgrade aswell and less cost.
Barry - Thanks for the plug but they have now sold mate. :afro:
karls3abo
« Reply #9 on: 29 September 2011, 01:22 »
Thanks muchly for that, really useful.
