Author Topic: Gti 8v digi rough running  (Read 1780 times)
Offline Craigwilson
« on: 26 September 2011, 16:23 »
My gti 8v digi has just started running really rough when it ticks over it jumps about and sometimes cuts out then wen i rev it it kina hesitates untill it pulls through.
Its had:
Plugs
Leads
Dizzzy cap
Rotor arm
Coil
Idle stableisation valve
Maf
Ecu
Ignition switch
Any ideas ?
Offline apie2004
Re: Gti 8v digi rough running
« Reply #1 on: 26 September 2011, 20:05 »
Fuel pump?
Offline Craigwilson
« Reply #2 on: 26 September 2011, 20:21 »
To be honest i did suspect that but which one the pickup or the actul pump because the actual pump is only a few years old the pick up is origional.
« Reply #3 on: 27 September 2011, 10:51 »
Might be worth trying a coolant temp sender.
