Author Topic: Hole in firewall?  (Read 3293 times)
Offline gtirobbie
Hole in firewall?
« on: 25 September 2011, 15:44 »
I'm just in the middle of fitting a boost gauge and I'm having trouble to find the hole for the hose to go through on the firewall, can anyone help guiding me this?
jamie16v
Re: Hole in firewall?
« Reply #1 on: 25 September 2011, 16:15 »
have a look under the header tank by the abs unit, share the hole with the main wiring loom.
Offline daz veedub
  • Operation 1.8t bolf
« Reply #2 on: 25 September 2011, 16:17 »
or through the bonnet cable gromit  :undecided:
jamie16v
« Reply #3 on: 25 September 2011, 16:25 »
valid point
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #4 on: 25 September 2011, 16:39 »
When I fitted one to my Leon (which is basically the same) I used the main loom gromit on the far passenger side of the firewall/bulkhead. I simply pushed a hole through with a screwdriver offset to the centre of the gromit as to not hit any wires. Taped the vacuum pipe to a bit of welding wire than just fed it through into the car.
Offline gtirobbie
« Reply #5 on: 25 September 2011, 17:44 »
I've been defeated! After taking half the dashboard apart i Just could not workout how to get the hose through to the gauge so will have to have another attempt at some other point, thanks for the advice anyway
« Reply #6 on: 25 September 2011, 20:21 »
Use the grommet for the bonnet release cable but make sure you reseal it afterwards.
« Last Edit: 25 September 2011, 20:28 by Wayne »
Offline gm8
« Reply #7 on: 25 September 2011, 20:25 »
i kinda cheated wi mine for simplicity , out through drivers door loom , through wing into bay , there is space , i used a big cable tie to poke it all through.
Offline Scott D
« Reply #8 on: 25 September 2011, 21:02 »
as already said grommet for the bonnet release cable is probably the easiest
lift the scuttle panel up slightly on the drivers side and you'll see the grommet then route down into fuse box for wiring to dimmer switch
are some guides about on the t'interweb
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline gtirobbie
« Reply #9 on: 25 September 2011, 23:25 »
Cool cheers for all the advice!
