Poll
horns coming on without pressing!!! gti mk2
horns stuck on
0 (0%)
horns stuck on
1 (100%)
Total Members Voted: 1
Author Topic: mk2 gti horns stuck on  (Read 2805 times)
Offline darren2285
  • gti 1
« on: 25 September 2011, 13:42 »
Hi Need help please!  :cry: My horns sound when I try to put the steering wheel back on without me pressing it when contacting it to the colum. Ive tried a curcuit tester on the wires to the horn and they are both live??? thanks in advance.
dh
Offline Jay
  • balding fat cvnt
Re: mk2 gti horns stuck on
« Reply #1 on: 25 September 2011, 13:48 »
My vote is for horn stuck on.
Offline mad4vws
« Reply #2 on: 25 September 2011, 14:37 »
disconnect 1 is if that makes a difference .
BREAKING VW GOLF'S
Mk2/ MK3'S ALL DAY LONG. PM FOR ANY PARTS!!  ON 07813936583
Offline darren2285
  • gti 1
« Reply #3 on: 25 September 2011, 15:30 »
Tried that but still the same aaaaahhhhhh!
dh
Offline clipperjay
« Reply #4 on: 25 September 2011, 18:31 »
Find the horm then test if its an open circuit at the horn end?
Offline darren2285
  • gti 1
« Reply #5 on: 25 September 2011, 20:21 »
Whats an opoen circuit mate :huh: lol not to hot on electrics
dh
Offline clipperjay
« Reply #6 on: 25 September 2011, 21:35 »
Simple really, its like a light bulb and two wires once the battery has a postive and negative it creates the open circuit.
You take away one side it would be called a switch or closed circuit. You need to see if the horn is somewhere stuck open i.e the connection at the horm itself or the pusher is stuck connected. Reading your posts the push switch makes no difference so I would just either replace the horn itself or test it out if you can make it honk by by passing a seperate positive and negative battery feed to test it! Hope that made sense? There can only be three things wrong horn, wires touching, push button touching. Thats all there is to it really. Open or closed noise or no noise.
Offline Sam
  • Sam I am
« Reply #7 on: 26 September 2011, 09:50 »
Mine did this, it will be the threads gone on the screw holes that hold your stalk set to the metal plate. My solution was to remove the screws and find identical ones with a courser thread.
Offline darren2285
  • gti 1
« Reply #8 on: 01 October 2011, 12:21 »
Yes i Found when I take screws out of the stalks its ok!! Ill try new flat screws and see how it is. thanks guys no your responses and let ya know.  :grin:
dh
