Author Topic: Whiteline front anti roll bar question?  (Read 1600 times)
Offline badboybunty
« on: 25 September 2011, 02:51 »
hi all after searching for hours cannot find the info i need im in the process of dropping my golf on jom coilovers im on 18 inch rs6 wheels i have took the rear pearches out to get the rear how i like it! hower looks like the front drop gonna be about -65 mm ish so i know gonna run into roll bar issues so looking at getting a new anti roll bar
im looking at the 22mm whiteline roll bar but as the bar goes under the driveshaft do u need to buy diffrent drop links or do u retain the standard drop links??
what bar do u think is the best as im no to this stuff and finding a bit confussing cheers liam
Offline GunnerCP
Re: Whiteline front anti roll bar question?
« Reply #1 on: 25 September 2011, 02:56 »
You might need a notch on the drivers side if you're really winding the coils down too....
I have adjustable droplinks on mine, with some 'spacers' but have seen threads where people have used standard droplinks with TT/R32 arb which is much the same principle as the whiteline one.
Better stock up on inner n/s cv's too!
Offline badboybunty
« Reply #2 on: 25 September 2011, 03:18 »
well i wasnt going that low on the front just so i can get 1 finger inbetween wing and tyre but the rear i put rear pearches in on lowest setting and i still had a 2 finger gap between wheel and arch thats y i took the rear pearches outthe rear sits now with under 1 finger gap but the car still up on fron end as i havent installed the front coilovers working to much at the moment so do a couple of hours on the car a day but all i wanted was a finger gap allround :smiley:
this is how i want my car to look on the drop the rear is like that! as spaced out 15mm but not sure if these are 19 rs6 and what drop he is on
« Last Edit: 25 September 2011, 03:29 by badboybunty »
Offline AD1.8T
« Reply #3 on: 25 September 2011, 17:17 »
I want that car ! Are all rs6 wheels 5x112 ?
Offline badboybunty
« Reply #4 on: 25 September 2011, 18:04 »
Mine are rs6 replicas and are 5 x 100 so direct fit mate
