Author Topic: cross threaded wheel nuts/hub  (Read 1926 times)
Offline hickles
« on: 24 September 2011, 20:35 »
went to take my rear wheels off today to sort the coilovers out, to find out once the wheel was off, that 1 of the bolts was cross threaded. tried to put a bolt back on once i had sorted the suspension and it cross threaded that, so i think it must be the hub that the thread has gone on, is the thread replaceble or do i need a whole new hub? its drivers side rear. dont think its safe to drive with 3 bolts in one wheel...
Turbo power!
jamie16v
Re: cross threaded wheel nuts/hub
« Reply #1 on: 24 September 2011, 20:53 »
actually, you can get away with driving with three bolts, i wouldnt leave it like that forever though..  get it fixed...
Offline daz veedub
  • Operation 1.8t bolf
« Reply #2 on: 24 September 2011, 20:54 »
loads of mk4s being broke so be able get another cheap enough mate be ok without 1 bolt but like jamie said get it replaced soon
Offline hickles
« Reply #3 on: 24 September 2011, 21:03 »
so is it a whole new hub deal? well the wheel has 3 bolts done up tight, one half tight and the other one just spinning.
Turbo power!
Offline daz veedub
« Reply #4 on: 24 September 2011, 21:07 »
yeah will be new/2nd hand hub needed especiallly if the bolt is just spinning
leave that 1 out till u source a hub
Offline hickles
« Reply #5 on: 24 September 2011, 21:10 »
at least i know that :D  well it is out now as the bolts completely foooked.
Turbo power!
« Reply #6 on: 25 September 2011, 00:06 »
See if you can get the thread cleaned up with a tap 1st.
Offline hickles
« Reply #7 on: 25 September 2011, 15:01 »
havent got a tapping tools and none of my mates do, so it will probably be just as easy to go to a garage.
Turbo power!
