Author Topic: Door dropped 3door  (Read 2542 times)
Offline Kus
Door dropped 3door
« on: 22 September 2011, 20:59 »
My door has slightly drop and the door slightly hits the door catch. Is this a common fault and does anyone know whats causing it so i can fix it..??
Offline andybod
Re: Door dropped 3door
« Reply #1 on: 22 September 2011, 21:51 »
it'll be a bit of wear in the door hinge pins easiest option is to carefully put a jack under the door and jack it up a bit
Offline Granta Gti
« Reply #2 on: 22 September 2011, 23:02 »
Very very coomon  :smiley:
I put the jack under the door around the puddle light and jacked it up and jumped on the sill to bend it back !
Offline Kus
« Reply #3 on: 22 September 2011, 23:29 »
Risky kent  :grin:
Offline Dave_IOW
« Reply #4 on: 23 September 2011, 00:06 »
Yeah block of wood under door, jack back up, pikey fixes are always the best  :smiley:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline daz veedub
  • Operation 1.8t bolf
« Reply #5 on: 23 September 2011, 09:22 »
bout quarter the way down page mk4 door drop  :wink:
http://uk-mkivs.net/forums/t/56052.aspx
Offline Tazzy
« Reply #6 on: 29 September 2011, 18:03 »
mines also dropped, obviously a common 3-door mk4 problem, mines dropped about 15mm, its actually rubbing on the frame as i close the door and taking paint off on sill
ive been advised not to do whats been mentioed, ie, put washers behind the lower hinge (as this will put the door out of sync) or jack the door up (as bending the metal will make it weak so it will only drop again)
what other options are there?
If It Comes Off, Modify It!
Offline daz veedub
« Reply #7 on: 29 September 2011, 19:30 »
only other option really is find a mk4 thats being broke that hasnt got dropped doors and get the hinges or new hinges
paul james
« Reply #8 on: 29 September 2011, 20:02 »
this happens on my 5dr unfortunately it is a common fault with age because their heavy doors & the hinges get weak' but there is a temporary fix.. put a 10mm socket in between the lower hinge & go to close the door, dont slam it! just put a bit of pressure on it & let go & again & let go about 10 times do this & take the socket out.. look at where the top of the dr lines up with the rear & u'll notice they've matched up again :smiley: its just temporary fix that'll last a while but they will drop again  :sad: i cant be bothered to replace the hinges so i use this method every few months lol :wink:
Offline Tazzy
« Reply #9 on: 02 October 2011, 20:41 »
how can both hinges bend though?
my drivers door card is alco broke (the mounting clips) but as the door is knackered, this will just break the new clips as well
