Author Topic: Decat  (Read 2774 times)
jockgti
Decat
« on: 21 September 2011, 16:33 »
Hi,if i fit a new downpipe and decat obviously that will flag engine management lights on dash,did i read somewhere that this can be sorted with a quick remap fix? if so what happens when its MOT time and the cat goes back on?
Offline Dave_IOW
Re: Decat
« Reply #1 on: 21 September 2011, 17:22 »
First part is a yes.
2nd no idea
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline barrym381
Re: Decat
« Reply #2 on: 21 September 2011, 18:14 »
most de-cats systems are a simple bolt on-off so easy swap come mot time but as long as emissions are ok shouldnt be a prob
jockgti
Re: Decat
« Reply #3 on: 21 September 2011, 18:33 »
i was wondering more if the bit of code they change/delete would make everything work ok when cat is put back on
Offline daz veedub
  • Operation 1.8t bolf
Re: Decat
« Reply #4 on: 21 September 2011, 19:16 »
when i had cat put back on for m.o.t had no lights come on  :undecided:
and same when decat put back on after had no problems
Offline magsmagsmags
  • Mk4 Golf GTI 1.8T (AUM)
Re: Decat
« Reply #5 on: 21 September 2011, 19:28 »
as far as i know all thats done when they map the light out is increasing the threshold on the second lambda so when its reading high emissions (which would normally be as a result of a knackered cat) it doesn't show anything. If that is the case, then putting the cat back in still wouldn't show any lights as it'll be well within the tresholds
~Mags~
jockgti
Re: Decat
« Reply #6 on: 21 September 2011, 19:33 »
ok cool a downpipe and decat it is then
Offline km
Re: Decat
« Reply #7 on: 21 September 2011, 19:35 »
am i right in saying early golfs only have 1 lambda sensor so there would't be any lights anyway?
Offline stevelfc
Re: Decat
« Reply #8 on: 21 September 2011, 20:44 »
yes only 1 lamba sensor but this still can bring on the engine light or put it in limp mode as the sensor wont be reading the exhaust gases
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Decat
« Reply #9 on: 21 September 2011, 21:41 »
no it won't as they don't have an engine management light  :grin:
Also they read the gasses before the cat so a decat doesn't affect the ECU at all
