Author Topic: big prob help needed  (Read 916 times)
Offline dam088888
« on: 21 September 2011, 13:20 »
Hi all just on way home today and all of a sudden loads of noise from front wheels when you brake like pads are all worn metel on metel but pads and disc are fine so jacked it up and spin the wheels and it spins a bit then there is resistance and makes a noise like the abs is trying to work so I unpluged abs plugs on wheels spun them and no noise so thought bonus its them took for a drive to test and still same when you step on brake loads of noise please help
2000 agu 1.8t lowered 55mm,cream mirrors and wheels,stage 1 map, forge 007p,
Offline GunnerCP
Re: big prob help needed
« Reply #1 on: 21 September 2011, 15:36 »
There's no stones or nothing trapped at all? The splash guards aren't bent and touching the disc at all?
Offline dam088888
« Reply #2 on: 21 September 2011, 16:35 »
Think you might have been right with the stones as been out again for a blast and it went
« Reply #3 on: 21 September 2011, 23:54 »
Sounds like a stone trapped. :smiley:
Offline daz veedub
  • Operation 1.8t bolf
« Reply #4 on: 22 September 2011, 13:24 »
id say stone trapped aswell the amount of times ive had to pull over and take a 1 out is countless  :angry:
