Author Topic: turn off immobiliser  (Read 1189 times)
Offline dam088888
« on: 21 September 2011, 09:41 »
So no joy with other threads on my immobileser active fault which happens only some times but looks like if it goes could be costly so can I turn off the immobiliser for good if where can I get it done or can any one do it for me
2000 agu 1.8t lowered 55mm,cream mirrors and wheels,stage 1 map, forge 007p,
Offline barrym381
Re: turn off immobiliser
« Reply #1 on: 21 September 2011, 09:44 »
it can be turned off for good but you tried sorting it 1st
Offline dam088888
« Reply #2 on: 21 September 2011, 09:52 »
Don't know where to start don't want to spend loads on keys and clocks so thought would be easy to turn off do u know where or any one that can do it I take it dealers won't do it
Offline barrym381
« Reply #3 on: 21 September 2011, 09:58 »
have a wee look in hear mate might help you an the dealer could do it but would prob be cheaper if you could find some1 local with the software needed
http://www.golfgtiforum.co.uk/index.php?topic=77197.0
Offline dam088888
« Reply #4 on: 21 September 2011, 10:12 »
I just read a thread where same thing was happing to him be clean connecter on back of insturment cluster and the one on the ignition barel coil and worked fine ever since but he says you have to take steering wheel off to get to the ignition coil one is that right can't I just remove the steering colom cowling
Offline barrym381
« Reply #5 on: 21 September 2011, 10:15 »
personally i dont know mate but im sure some1 on hear does hope u get it sorted though  :wink:
Offline dam088888
« Reply #6 on: 21 September 2011, 10:25 »
Yeah hope so to mate cheers any way
Offline dam088888
« Reply #7 on: 21 September 2011, 10:52 »
If I want to unplug. The cluster should I disconnect the bat first will it be ok to just disconnect it and plug back in won't throw up any codes if not start
