Author Topic: Indicator when turning Right  (Read 1812 times)
Offline mr wong
« on: 22 April 2005, 20:00 »
My indicator has started going at twice the speed when turning right only. It is really trivial, but it is seriously annoying me. Is it just a relay or a fuse that needs replacing?????
Any help appreciated before I rip the indicator stalk off in a temper! :angry: :shocked:
Offline Overseer
Re: Indicator when turning Right
« Reply #1 on: 22 April 2005, 21:32 »
no. it means one of your bulbs is gone ;)
Offline mr wong
« Reply #2 on: 22 April 2005, 21:36 »
Fantastic, i never thought of that!
Although, i've had to replace a few bulbs lately! maybe the wattage on the new bulbs is the problem!??
Offline Overseer
« Reply #3 on: 22 April 2005, 21:41 »
hmm dunno..
i just know that they flash faster if a bulb is gone.. so turn em on and get out n look..
if its not that then i dont know..
i only had this happen myself a few weeks ago :)
Offline mysticman aka polypathetic
« Reply #4 on: 22 April 2005, 22:15 »
i'd say it was a bulb blown too happened to me on all sorts of cars i've had and with the same result
check your bulbs chap
jay
Offline gibby
« Reply #5 on: 23 April 2005, 00:33 »
If it's not the bulb then it could also be a loose wire somewhere as I had the same happen to me (ok, it's a mk1 cab but its the same principal) the other week. If it's the bulb then you know the problem, but if the bulb is ok you'll need to do a circuit test to trace where the problem is.
......now officially dubless.
Offline mr wong
« Reply #6 on: 23 April 2005, 16:36 »
Ch3ears  :smiley: guys,
my indicator on the front fog lights has blown.
will go and get a buld on monday!
Offline AudiA8Quattro
« Reply #7 on: 24 April 2005, 11:38 »
If you have lots of bulbs blowing all the time then check your voltage regulator is working properly.
