Author Topic: Hot engine  (Read 1236 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
Hot engine
« on: 20 September 2011, 18:18 »
my engine gets really hot after driving just about 5 mins, not even that. The manifold gets very hot and you can feel the heat when standing outside with the bonnet closed. the temperature gauge is normal though and does not show any signs of over heating  :huh: Could this be a maf problem? as I also seem to consistently have the 17705 code, even after changing all the pcv pipework.
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline bbewekim
Re: Hot engine
« Reply #1 on: 20 September 2011, 18:56 »
the gauge on the dash is coolant temp not oil temp... have you checked what temperature its getting to on VCDS? it should be around the 88-93 degree mark when at full temp. Mine was running 102-105 at points it was the thermostat.
Re: Hot engine
« Reply #2 on: 20 September 2011, 19:11 »
that will explain why the gauge on the dash is ok then  :embarassed:  :laugh:
I don't have a vag com.
