Author Topic: 2 new problems...ARRGHHH  (Read 1063 times)
Offline mdibb2009
« on: 19 September 2011, 22:59 »
Hi guys, 2 new problems with my car now :
Fault is : SUPPLY VOLTAGE TERMINAL 30 (ABS)
The other is that when I start the engine the reverse lights are constantly on ??
The car has just had an engine swap for another identical engine (AKL)
Any ideas guys ?
Thanks very much
Re: 2 new problems...ARRGHHH
« Reply #1 on: 19 September 2011, 23:39 »
Reverse lights could be a faulty switch, unplug it and see if they go out.
Offline Dannyavw
« Reply #2 on: 20 September 2011, 19:17 »
Double check strip fuses on top of battery if blown I've seen this abs fault many times before all down to a fuse
