Author Topic: 94 VR6 Battery Dying! Temp Sender?  (Read 1263 times)
Offline rossbarry1
« on: 19 September 2011, 16:40 »
My VR's fan keeps running when engine is turned off unless i unplug it and then the battery goes flat, is this because of a faulty temp sensor maybe? causing the fan and coolant fan to run on? if so which sensor is it under the FPR as i have 2?
Thanks
Re: 94 VR6 Battery Dying! Temp Sender?
« Reply #1 on: 19 September 2011, 18:09 »
Unplug the switch on the radiator as I suspect that is your problem
Offline rossbarry1
« Reply #2 on: 19 September 2011, 21:35 »
what the radiator fan plug?
« Reply #3 on: 19 September 2011, 23:47 »
Nope, the fan sender on the rad.
