Author Topic: ignition switch  (Read 868 times)
Offline dam088888
ignition switch
« on: 19 September 2011, 15:13 »
Hi all got an intermittent fault sometimes when I start car it goes straight off with immobileliser active but only sometimes so I take key out lock unlock then normally starts so after some searching may be ignition switch so of I get a second hand one to try is it a straight swap for mine or will it need codeing to car or any thing or should I get a second hand barrel with swicth and key or will that need codeing too not to sure what to do as don't want it to happen then not start at all and be stuck. So try get it sorted before it stops all together
2000 agu 1.8t lowered 55mm,cream mirrors and wheels,stage 1 map, forge 007p,
Offline dam088888
Re: ignition switch
« Reply #1 on: 20 September 2011, 08:55 »
Any help boys
Offline Rhyso
Re: ignition switch
« Reply #2 on: 20 September 2011, 08:57 »
Could also be a weak battery in your key
From what I remember, removing the ignition switch is a complete pain in the arse  :angry:
Fairly sure it will need coding too
Offline dam088888
Re: ignition switch
« Reply #3 on: 20 September 2011, 17:17 »
Battery changed still no joy any more ideas lads
