Author Topic: JOM R32 front bumper  (Read 1481 times)
Offline jonesltd
  • MK7 R
« on: 19 September 2011, 10:39 »
Seen one on ebay of a JOM and wondered what the fitment was like?
Item number 230674634511
If you cant find it......Grind it
Offline jonesltd
  • MK7 R
Re: JOM R32 front bumper
« Reply #1 on: 19 September 2011, 19:00 »
Ordered bumper..dead excited!!! Pics up soon
Jus a question what screws do I need to use? Need to start from scratch as I had a fibreglass bumper and glued it on :(
« Last Edit: 19 September 2011, 19:21 by jonesltd »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 19 September 2011, 19:37 »
Any idea if it mounts in the same way as a standard bumper?
Offline jonesltd
  • MK7 R
« Reply #3 on: 19 September 2011, 19:43 »
I really don't know? The bumper says it can fit 1.9 which is what I have
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 19 September 2011, 19:55 »
from the fuzzy pics it looks like there are bolt holes near the headlights, there might be some on the top too, just can't see it. Do you have any of the bolts that fix a standard bumper on?
Offline jonesltd
  • MK7 R
« Reply #5 on: 19 September 2011, 19:59 »
Nope I didn't fit it and didn't get any back either. They were 14pence for the rear and only needed 6 so was wondering if it's the same process for the front? Or do I ring vw dub and say it's a tdi with r32 bumper and pray they no?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 19 September 2011, 20:02 »
nah I'll find you the number in a bit  :wink:
Offline GTI:Gibbo
« Reply #7 on: 19 September 2011, 22:34 »
I think you can use the clips for your standard Mk4 bumper with this.
Offline DubAndDubber
« Reply #8 on: 19 September 2011, 22:46 »
I got the same one mate, goes on exactly the same way as the standard bumper, the 4 screws under each arch are pretty standard, just use screw brackets. Then there is 3 bolts in the grill that you'll need, theyll need to be right for a flush fit. It's a very good fit, i'd say its near perfect but just a tiny tiny bit big around the headlights, but better than being to small i suppose!
Mk5 Golf Gti 06'
