Author Topic: Warning light help please guys  (Read 2008 times)
Offline mdibb2009
« on: 18 September 2011, 20:09 »
Right guys just got my car back from having an engine swap, like for like swap 1.6 AKL engine.
Everything seems fine apart from I now have a red warning light that flashes on the dashboard and bleeps 3 times when I start the car (!)
The guy said he has checked over all the wiring etc... and plugged it into his machine but its not showing up any faults.
Seems strange as there was no light before the swap and its all of a sudden appeared.
Checked fluid level and all is fine
Any ideas guys ?
Thanks very much
jamie16v
Re: Warning light help please guys
« Reply #1 on: 18 September 2011, 20:14 »
which light? if its the coolant level then it could be the sensor in the header tank, which means you need a new header tank, not expensive either!
« Last Edit: 18 September 2011, 20:17 by jamie16v »
Offline mdibb2009
« Reply #2 on: 18 September 2011, 20:23 »
The red light that looks like this mate : (!)
Thanks very much
Offline mdibb2009
« Reply #3 on: 18 September 2011, 20:24 »
Forgot to mention it only comes on when I rev the engine after I have started the car, not as soon as its started.
Thanks
jamie16v
« Reply #4 on: 18 September 2011, 20:29 »
probably either break fluid sensor or brake pads reaching their limit. re-check brake fluid resevoir!
« Reply #5 on: 18 September 2011, 20:29 »
Thanks
Sounds more like the oil pressure light  :undecided:
Offline mdibb2009
« Reply #6 on: 18 September 2011, 20:34 »
Thanks for the replies guys.
Should the brake fluid be filled upto the brim of the resevoir ?
I know it has MIN and MAX levels on but my max level just says MAX with an arrow pointing towards the top of the resevior so wasnt sure how  much to put in ( Its not at the top at the minute by the way )
Thanks very much
jamie16v
« Reply #7 on: 18 September 2011, 21:23 »
Thanks
you got a point as in it only happens when he revs, but wouldnt the light shaped like an oil can light up?..
the oil warning light illuminates when you turn the ignition on but goes out when you start as the pump supplies pressure.
Offline mdibb2009
« Reply #8 on: 18 September 2011, 21:41 »
Thanks guys, yes I looked into that but was told if it was the oil pressure it would be a red oil can light, and an amber oil can light if it was low oil so they ruled that out.
Thanks again
jamie16v
« Reply #9 on: 18 September 2011, 22:05 »
check the brake pad thickness or the wire going to the brake pad warning sensor!
