Author Topic: dodgy engine idle?  (Read 3170 times)
Offline joe skandal
dodgy engine idle?
« on: 17 September 2011, 22:17 »
Hey. Can someone please tell me how to fix a ticking over problem? When I start the car first time and its sitting idle, it fluctuates between 15-20000 rpm.
Is this actually a problem? I mean, I understand that the car needs to warm up a bit, bit it just doesn't sound healthy.
It will do this for a while until warmed up. Any ideas how to sort this out?
Cheers.
Joe
-Joe
Turn on, tune in, drop out..!
Offline jimojameso
Re: dodgy engine idle?
« Reply #1 on: 19 September 2011, 15:18 »
Try cleaning the ISV with brake cleaner. If it stabilises you can drop the idle with the idle screw.
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #2 on: 19 September 2011, 15:53 »
If my Golf idled between 15-20,000 rpm, I'd dare say it was "a problem"
 :rolleyes:
 :grin:
Offline walchy01
« Reply #3 on: 19 September 2011, 20:45 »
My 16v ticks  over from cold around 1200 to 1400, I think that may be more like the norm??? :embarassed:
Drops to 900 to 950 once warm.....
Offline joe skandal
« Reply #4 on: 19 September 2011, 23:10 »
Cool, thanks.
-Joe
Offline apie2004
« Reply #5 on: 20 September 2011, 17:55 »
 :rolleyes:
 :grin:
Or some excellent news!
Offline mk2addict
« Reply #6 on: 20 October 2011, 23:18 »
I had the same problem on mu 8v ended up bein throttle body gasket and vacum hoses to the brake servo had a duff non return valve,which was lettin in air after the airflow meter. Which made I rev itself embaressin in traffic lol
« Reply #7 on: 20 October 2011, 23:22 »
 :rolleyes:
Go and have a root around in the maintenance section. Re:  setup.
Offline [han]
  • Graphic Designer for Haribo
« Reply #8 on: 21 October 2011, 20:05 »
ISV?
Offline Snoopy
  • Geoff.
« Reply #9 on: 22 October 2011, 15:19 »
[Han] I think your asking what an ISV is? ISV= idle stabilizer valve.
Poor idle could be a number of things. I went to look at an 8V with a similar idle problem last week.
It could be the ISV, blue temp sensor if its a digifant, metering head, throttle valve, air leak on inlet manifold pipes, cold start valve if its an early Kjet , sticking valve, ECU etc etc.
« Last Edit: 22 October 2011, 16:26 by Snoopy »
Current Garage:
35+ years of GTI ownership.
