Author Topic: bad metal sounding vibration in high revs  (Read 1910 times)
Offline senninha1981
« on: 17 September 2011, 18:06 »
I have a metal vibration/buzzing sound over the 4200rpm mark,
I have had a good lock underneath all heatshields are sucure and no vibrations and nothing else seems a miss.
Its sort of under the rear seats underneath the car where its coming from.
Any ideas :undecided:
I thought it might of been the fuel pump as its sort of a metallicy sort of buzzing sound?
Offline gasketface
Re: bad metal sounding vibration in high revs
« Reply #1 on: 17 September 2011, 18:10 »
Could be many things but does the rear mounting for the centre section of the exhaust hit the brace ?.I mean the one towards the rear of the car that has two rubbers on it ?.Check the rubbers.
« Reply #2 on: 17 September 2011, 18:35 »
no all is fine in that department
Offline tshirt2k
  • Been there...Done that...
« Reply #3 on: 17 September 2011, 18:45 »
Are you sure you're not confusing it with pinking? Or detonation
Mk3 ABF 16VT Megasquirt V3
Offline stainesy
« Reply #4 on: 17 September 2011, 18:49 »
what is pinking?
« Reply #6 on: 17 September 2011, 19:20 »
No coming from the back under the seat area
« Reply #7 on: 17 September 2011, 19:22 »
could it be the fuel pump being under load at certain rpm making it sound a metalicy rattle, do they have problems?
Offline tshirt2k
« Reply #8 on: 17 September 2011, 22:12 »
Probably a heat shield.
Offline gasketface
« Reply #9 on: 17 September 2011, 22:16 »
Check your heatshield above your backbox.It's held on by round retainer thingies (  :smiley: ) that corrode and fall off (as one of mine recently did).They are used widely on VW's,it's the same part that holds the plastic power steering pump/belt cover on.
