Author Topic: Brake Lines  (Read 6001 times)
Offline tech1889
  • Mk2 GTI FTW !!
Re: Brake Lines
« Reply #20 on: 19 September 2011, 21:41 »
would a £5 pipe bender be adequate ?
Offline The Mighty Elvi
  • I'm better than you today.
Re: Brake Lines
« Reply #21 on: 19 September 2011, 21:45 »
Worked for Hardy Kruger when building his plane in the Sahara.   :smug:
a) the UK's not renowned for being dry, the Sahara is.  Sand is far more likely to stick in the particularly small pipes due to the higher ambient moisture content.
b) did he use it specifically in the brake pipes?
No Fuel line.  More hardcore.  I don't think brakes were his primary concern at the time.  Well, I think flushing out the sand with water will get it clean.  Or use table salt.  :nerd:
Offline molegti
Re: Brake Lines
« Reply #22 on: 20 September 2011, 12:33 »
I'd be concerned about getting the sand back out. Its not necassary you can bend brake pike with your hands you just need to be careful.
Offline ritmo
Re: Brake Lines
« Reply #23 on: 20 September 2011, 13:35 »
.....concider your nipples!!!! make sure they are loose first!! :wink:
Offline tech1889
  • Mk2 GTI FTW !!
Re: Brake Lines
« Reply #24 on: 20 September 2011, 16:16 »
what on the MC and such ?
Offline Diamond Hell
  • Opinions я Us
Re: Brake Lines
« Reply #25 on: 20 September 2011, 20:30 »
I'm guessing he means on the calipers, so you don't get the new pipe made up, then shear off a nipple trying to bleed the system up.
Fair advice.
Offline ritmo
Re: Brake Lines
« Reply #26 on: 21 September 2011, 13:29 »
sorry for the random comment, a bit of light humour! :smiley:
I had brake pipes made up recently fitted them and went to bleed the system and the the niple on the caliper (as you said Dimond Hell) sheard off! had to replace the calipers too!!
A
Offline cняis
Re: Brake Lines
« Reply #27 on: 21 September 2011, 21:29 »
Can't understand why people think a motor factors will be able to do a better job at making brake lines than a careful owner who wants his brake lines to be neat / fit in all the factory clips etc
You want male m10 x 1.0 unions for 3/16 brake pipe
http://www.ebay.co.uk/itm/BRAKE-PIPE-UNIONS-M10-x-1mm-Short-male-suit-3-16-/160614758949?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item256562ba25
meh, this is why we make straight lengths, rather than pre-bending. The onus is then on the customer to f*** that up!
