Author Topic: Brake Lines  (Read 6001 times)
Offline tech1889
  • Mk2 GTI FTW !!
Re: Brake Lines
« Reply #10 on: 18 September 2011, 11:25 »
Thank you very much..
My motor factors want about 50-60 to cut s straight length and flare them.. This way will cost Roughly the same and I will have pipe left over and a flaring tool should I want to remake again makes sense to me  :wink:
Offline molegti
Re: Brake Lines
« Reply #11 on: 18 September 2011, 16:47 »
I made my own for the front, took the old ones off, measured them with some wire, cut the pipe to length and then followed the curves of the orignal. Make sure you put the ends on before you bend the pipe, maybe even tape them in place as they may get stuck behind a tight curve.
Offline Diamond Hell
  • Opinions я Us
Re: Brake Lines
« Reply #12 on: 18 September 2011, 18:52 »
I bought my brake kit from Frosts:
http://www.frost.co.uk/aumotive-brakes-tools.html
Including this tool:
http://www.frost.co.uk/aumotive-brakes-tools/brake-pipe-flaring-tool.html
Re-lined my Golf with it and I've replaced various other lines since.
I prefer bending lines by hand, because you get a lot closer to what you want.  Provided you support the pipe all along the section you're bending you should avoid kinking it - go for it - it'll save you money and aggro in the long run.
Offline tech1889
  • Mk2 GTI FTW !!
Re: Brake Lines
« Reply #13 on: 18 September 2011, 19:01 »
which kit you get mate ?? how do the flares come out with that kit ?
  • Opinions я Us
Re: Brake Lines
« Reply #14 on: 19 September 2011, 08:17 »
Flares come out fine.  I got a box of unions, couple of lengths of pipe and the flaring tool above.
It came out well in a PPC group test a couple of months ago.
I've done a fair number of ends and only had one screw up IIRC.  It's pretty simple to use.
Offline The Mighty Elvi
  • I'm better than you today.
Re: Brake Lines
« Reply #15 on: 19 September 2011, 10:19 »
Handy tip when bending pipes is to fill it with very dry sand.  This will stop the pipe collapsing into a kink at the bend.
Offline tech1889
  • Mk2 GTI FTW !!
Re: Brake Lines
« Reply #16 on: 19 September 2011, 12:27 »
Like shot blast sand ?
  • Opinions я Us
Re: Brake Lines
« Reply #17 on: 19 September 2011, 13:45 »
Don't think I'm keen on this idea - just support the pipe evenly and it should be fine.
Re: Brake Lines
« Reply #18 on: 19 September 2011, 14:49 »
Worked for Hardy Kruger when building his plane in the Sahara.   :smug:
  • Opinions я Us
Re: Brake Lines
« Reply #19 on: 19 September 2011, 21:33 »
a) the UK's not renowned for being dry, the Sahara is.  Sand is far more likely to stick in the particularly small pipes due to the higher ambient moisture content.
b) did he use it specifically in the brake pipes?
