Author Topic: ABF questions  (Read 7361 times)
Offline Neo Badness
  • Feet are for pedals
ABF questions
« on: 17 September 2011, 13:11 »
Anybody got a part number for this or if it's VW or SEAT bit. I think it's SEAT as it its bracket for cable actuator for hydro clutch.
If anybody knows where i can get one cheap/ got one for sale that'd be great too :smiley:
I'm also after the bit off the passat that will allow my speedo to read without changing my clocks. Don't know/ can't remember the part number name of it.
Offline tech1889
  • Mk2 GTI FTW !!
Re: ABF questions
« Reply #1 on: 17 September 2011, 13:16 »
what does that part above do ?
is it on any VW from that era ? if so try www.wagenstad.com
Offline Neo Badness
Re: ABF questions
« Reply #2 on: 17 September 2011, 13:37 »
It holds the cable actuator for the hydraulic clutch on the gearbox. I'll have a nosey at the link, ta.
Offline memt
  • i'm new
Re: ABF questions
« Reply #3 on: 19 September 2011, 15:35 »
Hi, not sure about the name for the first part, however i got a similar one from VW
PN: 357 199 356 cost £35.
And the speedo you want is the same as this one, it screws straight in http://www.ebay.co.uk/itm/Speedo-Cable-Volkswagen-GOLF-Mk2-1-3-83-91-/400237999973?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5d300b3765#ht_1858wt_992
I'm not having much luck getting hold of the actuator though, have you got one? I ordered one from VW but its been on backorder now for around a month.
EDIT! Just re-read what you put, are you using the hydraulic clutch or the cable one? I guess its an 02A gearbox too right?
« Last Edit: 19 September 2011, 15:38 by memt »
Offline Neo Badness
Re: ABF questions
« Reply #4 on: 19 September 2011, 23:01 »
Yeah buddy, I'm planning on using the mk3 g/box whilst retaining the clutch cable and avoiding the need to fit a pedal box etc.
I'm not sure if the 1.3 speedo cable will attach to the back of my clocks and then go to the mk3 g/box as it's electric speedo feed isn't it?
Offline memt
  • i'm new
Re: ABF questions
« Reply #5 on: 20 September 2011, 00:37 »
The electronic sender on the 02A box unscrews and the 1.3 one screws in and goes direct to the clocks.
You're doing the same conversion as me pretty much, how far along are you? I'm just waiting for the actuator then its MOT time.
Offline Neo Badness
Re: ABF questions
« Reply #6 on: 20 September 2011, 11:32 »
Ah, I see. I'll need to see if I have the electronic sender on the g/box.
I've got a few bits and bobs to sort out still. Clutch cable, speedo cable, bracket for clutch actuator, possibly the sender on g/box. Have recently become a student again so shoestring budget has gone to a spider thread budget :grin:
Offline memt
  • i'm new
Re: ABF questions
« Reply #7 on: 25 September 2011, 19:31 »
Do you know the part number of the clutch cable that you're using? On the one I have it seems as though the housing is too long, its a self adjusting Seat one.
Offline Diamond Hell
  • Opinions я Us
Re: ABF questions
« Reply #8 on: 25 September 2011, 23:11 »
I've used the SEAT units fine before now.  There should be a thread somewhere in here with the part numbers in it, too.  If they're installed properly they should just work.
Offline Neo Badness
Re: ABF questions
« Reply #9 on: 26 September 2011, 08:51 »
I was supposed to be getting a loan of the bracket pictured to copy it but hopefully I'll gt it sometime this week. I'll post up any part numbers I find and I'll also confirm the correct cable to use. I think it there were mutterings of a 1.3 Golf non adjusting one but I can't honestly say for certain at the mo'.
