Author Topic: got my new lights on what do you think  (Read 2719 times)
Offline mysticman aka polypathetic
« on: 21 April 2005, 21:54 »
:smiley:
and new fogs and indicator set
kingsmk2
Re: got my new lights on what do you think
« Reply #1 on: 21 April 2005, 22:14 »
they look good m8 bring it upto date....
Offline davero
« Reply #2 on: 21 April 2005, 22:59 »
they loook spot on m8, like headlights best
Offline davero
« Reply #3 on: 21 April 2005, 23:01 »
did you get sorted with loom for fogs: i did, took a bit of foraging
« Reply #4 on: 21 April 2005, 23:06 »
no got a few people on the case shouldn't be long i'm hoping
finally got the switch so its just a matter of time i even went to wayside to find out how much a new one was but ran out of the parts dept screamin at the quote of £222
funking havin a joke
just for a bit of bloody wire
Offline davero
« Reply #5 on: 21 April 2005, 23:17 »
FOOK, no way, a good auto electrician could make you one up for pence. Why not ask Dizzzie
« Reply #6 on: 21 April 2005, 23:23 »
i want to run them from the correct switch
so ideally i want to connect them to the big round connector above the rad
i could do it but I'll need to know which of the many female connectors are the fogs live
if anyone has an electrical plan of this connector that would be good or i could just spend an hour with my electric circuit tester find the wire that becomes live when i turn the fogs on
oh yeah what bulb do the fogs take
any ideas dave16v
cheers jay
Offline davero
« Reply #7 on: 21 April 2005, 23:42 »
i was looking at mine today, there is places on that loom for fogs to go with proper switch ,if you knew what you were doing. if you have connected the switch you will see that all lights, around switch are working, which means power is going somewhere. all that is needed issome wires to connect to blank bits on loom and 2 vw mk3 light connectorss
« Reply #8 on: 21 April 2005, 23:49 »
switch is working fine with the front fog 'on' light coming on i think i'll have a look tomorrow and see what i can do
cheers for the info dave
jay
Offline davero
« Reply #9 on: 22 April 2005, 00:41 »
no probs Jay in more or less same boat as you.
Dave
