Author Topic: Fuel pump constantly running  (Read 3959 times)
Offline Dannyavw
« on: 16 September 2011, 20:22 »
Hi I've fitted relay 30 in position 3 of fusebox On my mk2 vr6 conversion and my fuel pump is running all the time and I can't seem to get my indicator tell tales on mk3 dash pod to work, any suggestions cheers
Offline Diamond Hell
  • Opinions я Us
Re: Fuel pump constantly running
« Reply #1 on: 16 September 2011, 23:52 »
Is the ECU good?
Fuel pumps running all the time when off is an indicator of blown ECU due to disconnected earth in some circumstances.
Offline Dannyavw
« Reply #2 on: 17 September 2011, 07:53 »
Sorry  I'm not sure if I made myself clear enough the fuel pump runs all the time with relay 30 fitted with ignition on but constantly runs and if you turn ignition off it switches off. It primes but continues to run cheers
Offline SoundillusioN
« Reply #3 on: 17 September 2011, 09:48 »
Is it definitely the correct relay?  If it is, tried a replacement?
Offline Dannyavw
« Reply #4 on: 17 September 2011, 13:04 »
Swapped it from my mk3 gti and it does the same
« Reply #5 on: 17 September 2011, 22:14 »
Could be an ecu fault
  • Opinions я Us
« Reply #6 on: 18 September 2011, 18:54 »
As already posted - check the ECU in a known good car installation.
Offline lemski
  • 16v
« Reply #7 on: 19 September 2011, 14:26 »
I would put money on the ecu. An earth isnt tight somewhere.
Offline mk2bal
« Reply #8 on: 19 September 2011, 21:32 »
Check all earths continuity with a basic ohm meter
Offline madmanluke
« Reply #9 on: 20 September 2011, 10:12 »
Im going with the wrong relay or the relay for the old digifant ecu is still in the fusebox.
As far as I am aware OBD ecu's from VR's dont suffer the same ground fault as the old digifant ecu's do.
