Author Topic: My guide on removing rear wiper  (Read 9709 times)
Offline gtiballs61
  • Wanted-nearside wing in lp3g(flash red)
« on: 16 September 2011, 14:48 »
My quick guide on removing rear wiper.
step 1: Make a brew in a novelty mug(i used sponge bob for this job)
step 2: You will need, possy screwdriver,10mm socket and ratchet,13mm spanner,21mm socket or some good grips
step 3: pull away the black plastic cover on the wiper arm.
step 4: use the 13mm spanner to undo the first nut,once removed,the wiper arm should come off,i used a flat screwdriver to prise it off :angry:
step 5: Remove the cover on the iside off the boot by first undoing the screw located inside the handle.
step 6:Undo any wires that are connected to the motor,and the black pipe,now undo the big nut using a 21mm socket or grips
step 7:Now undo the 4 gold bolts using your 10mm socket,once undone remove the motor,i found removing it by pulling the right side out first.
step 8:Go to wickes and get a 25mm bung,these come in packs of 10 @ £1.58.
step 9:Give the area a clean up and bung in your bung.It may be a bit tight,but trust me it will fit.
step 10:Stand back and admire your mod for less than £2 :cool:
10 Easy steps.feel free to add any other info i may of missed out.
this took me 20 mins max :wink:
I also sprayed my vw badge matt black whilst i was in the diy mood :cool:
« Last Edit: 16 September 2011, 14:51 by gtiballs61 »
Offline VR6_Wherry
Re: My guide on removing rear wiper
« Reply #1 on: 16 September 2011, 14:53 »
Great write up there!  :cool:
Offline crazy_e
« Reply #2 on: 16 September 2011, 15:00 »
what about the rear washer  :rolleyes: aint that built in to the motor so that sitting in the boot if one of your (clever) mates press the button you get wet boot  :sad:
Offline VR6_Wherry
« Reply #3 on: 16 September 2011, 15:02 »
Not if you stick a screw in there like it did  :wink:
Offline gtiballs61
« Reply #4 on: 16 September 2011, 15:53 »
Yes as above :wink:
Thanks for the pointer,all the extra info helps :wink:
Offline boneybradley
  • Back in a Mk3...
« Reply #5 on: 16 September 2011, 21:49 »
I will move this to link in with the other guides (when I get time!)
so for now it's stickied here
  • Back in a Mk3...
« Reply #6 on: 16 September 2011, 22:32 »
done and unsticked
« Reply #7 on: 17 September 2011, 23:22 »
It is also worth pulling the pipe off the washer bottle.
Offline DUBboi12
« Reply #8 on: 25 March 2012, 17:44 »
Spot on mate works a treat :smiley:
