Author Topic: rear tyre scrub.  (Read 1716 times)
Offline CJA321
rear tyre scrub.
« on: 16 September 2011, 00:42 »
Hey guys wondering if you would have any advice for me.
I have a mk 3 3 door on stndard springs with 17" wheels on 225/45/17 tyres.
I bought the car with the 17s and they are allmost brand new vw replicas and look really good in ny opinion.I will upload photos shortly.
The problem is with weight in the back the tyres are getting torn to pieces on the outside edge.. and its not just over bumps, the arches are basicly sitting on the rear wheels.
Any easy fixes? heard a rumor about 40 profile tyres but cant see 5 percent making that much differance.
any input would be much apreciated. thanks in advance
- callum
Offline gtiballs61
  • Wanted-nearside wing in lp3g(flash red)
Re: rear tyre scrub.
« Reply #1 on: 16 September 2011, 08:24 »
Roll arches/ inner lip. 40/17 tyres.
Maybe some negative Camber.
Coil overs?
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 16 September 2011, 08:24 »
you might not scrub with 205/40x17 (correct mk3 size) as your tryes are too big!
Offline Len
« Reply #3 on: 16 September 2011, 08:54 »
Actually you can use 215/40
I have the 17x8 wheels with them on to prove it!
225 you can use with 5mm spacers!
www.sas.org.uk
www.the-ace.org.uk
« Reply #4 on: 16 September 2011, 10:57 »
225/40´s are too wide you need 205/40´s
  • Back in a Mk3...
« Reply #5 on: 16 September 2011, 12:27 »
len he said the tryes were catching on the outer arch....surely spacers will make it worse or make the wheels unfitable?
(I guess the offset is different to yours) b.tw 205/40 and use something like falken tryes (as they are nice and square on the sidewalls unlike some other bulgy makes)
Offline Len
« Reply #6 on: 16 September 2011, 12:59 »
With 225's they should rub against the struts! So he must have incorrect offset wheels!
www.sas.org.uk
www.the-ace.org.uk
Offline CJA321
« Reply #7 on: 16 September 2011, 13:42 »
Thanks for your replies guys. Theyre not rubbing on the strut at all. just the outside edges. would the 205/40's do the job then? Ill upload a photo when im home. at work atm :-( thanks again
« Reply #8 on: 16 September 2011, 14:38 »
 switching tyres should help, what offset are the wheels?
« Last Edit: 08 December 2011, 00:04 by Wayne »
Offline Screech16v
  • MK3 20vt AGU
« Reply #9 on: 16 September 2011, 19:30 »
