Author Topic: DTC Codes problem  (Read 1724 times)
Offline carpetviper
DTC Codes problem
« on: 15 September 2011, 19:40 »
Hi guys well todays been expensive and a little confusing.
I have had the problem of rough running for the last week so I did a vag test and got 00537 and 00520
These apparently are the lamda and the maf so I bit the bullet and replaced both today however after clearing the errors and running for a while the 00537 error keeps popping up has anyone got any ideas.
Offline tshirt2k
  • Been there...Done that...
Re: DTC Codes problem
« Reply #1 on: 15 September 2011, 20:01 »
I would check the lambda plug wiring. I had this problem with mine. The plug had wires snapped.
Mk3 ABF 16VT Megasquirt V3
Offline danmusic24
« Reply #2 on: 15 September 2011, 21:39 »
had same codes ages ago mate! reset ecu (disconect battery for the night) and try again...
also i had a split vacum hose,have a good look round and make sure everthing is air tight.. :smiley:
Offline carpetviper
« Reply #3 on: 16 September 2011, 20:31 »
How did u test the plug wires ?
Offline carpetviper
« Reply #4 on: 16 September 2011, 20:31 »
I havent done that yet might be one for sunday night.
Which vacum pipes were u on about do you mean the breathers on the front of the engine.
« Last Edit: 16 September 2011, 20:33 by carpetviper »
Offline tshirt2k
« Reply #5 on: 16 September 2011, 21:52 »
Check the plug on the loom for broken wires or test for voltages.
Offline danmusic24
« Reply #6 on: 17 September 2011, 08:55 »
check the black pipe that runs from right side of inlet manifold and follow it back,mine had a little split just behind the brake fluild filler and caused rough running.also i think sometimes you get false code readings,i tracked down a fault with my coolant sensor which i replaced and bingo! no more codes...
but got to be worth checking your wiring and connectors for faults and tshirt was saying and reset ecu :smiley:
Offline carpetviper
« Reply #7 on: 17 September 2011, 21:02 »
Just reset the ECU today if that doesnt work itll be a coolant sensor and then all new breathers in that order.
By the time im done it'll be nearly a new car lol.
Can you get stainless air intakes for the 8v
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #8 on: 18 September 2011, 07:31 »
Yes you can buy them on eBay.
Offline carpetviper
« Reply #9 on: 18 September 2011, 09:53 »
All the ones I have seen say not suitable for the 8v due to the maf
