Author Topic: weight lifting  (Read 6263 times)
Offline mwep201081
Re: weight lifting
« Reply #40 on: 16 September 2011, 17:58 »
I havnt read the rest of this, but a good site I'd recommend is www.stronglifts.com the guy who runs it knows what hes talking about and talks a lot of sence, he also has a downloadable 'book' which I suggest reading it talks a lot about the different styles/techniques etc and which are most effective
also hes not trying to sell anything like a lot of the other sites.
www.stronglifts.com
 :smiley: great minds
Offline tweed
Re: weight lifting
« Reply #41 on: 16 September 2011, 18:23 »
I aint read any posts so sorry if it's said.
To body build you don't want to lift heavy weight! you want to be doing 12 to 15 reps. GOOD reps. and at the peak of every rep really squeeze and tense the muscle your working. If you can't do it right and have to swing/ move your body to lift the weight, it's too heavy and go lighter.
Also do two exercises. So say your doing a shoulder press as soon as you finish the set do triceps extension then, a 45 sec break. or leg press etc.
I don't take any protein shakes or supplements, waste of money for the gain witch is small.
I'm 6ft1, 100kg, 48" chest, 18" arms. I'm not the biggest, but not small. been training hard for 3 years 5/6 times a week. I've never made a routine, I always change every week to not let the muscle get used to what I'm doing. there's so many exercises for one muscle groups and you only need to do 4 different exercises with sets of 4. You can do to much and you only want to train for 45/60 mins.
I'm about to go gym now and I'l do chest today. incline bench press, incline flys. decline cables and around the worlds. might do close grip barbell bench pres too.
And another thing to get a good pump is to do a quarter press. Say your doing bench press (best way to describe) bring the bar down to your chest, always a inch above. then do a quarter press, just push it up a little bit, then bring it back down, then do a fall extension. That's one rep and you can do that with everything!
Look on youtube to see how to do any exercise the correct way.  :wink: hope that helps.
Offline matg340
Re: weight lifting
« Reply #42 on: 16 September 2011, 18:34 »
Thanks again folks for the great info :) I won't be doin any steroids as I've mentioned I would feel like I've cheated myself . Checked out the 5x5 routine an it seems good , gonna give it a try , I suppose like every new starter I assumed I would be doing as much as poss every time I pick em up , yet it seems that fewer exercises done correctly Is the way forward :) there is a gym round the corner from work so gonna call in tomorrow .
Thanks again folks a lot of useful info there much appreciated ....
preserve wildlife.......PICKLE A SQUIRREL !!!!!!!!!!!!
Offline bored_Welsh_lad
Re: weight lifting
« Reply #43 on: 17 September 2011, 14:48 »
I recommend P90X
That is all...
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline Phil1980
Re: weight lifting
« Reply #44 on: 18 September 2011, 12:29 »
P90X is ok a couple of guys I work with used that programme but some of the sessions are an hour long, 20minutes of high intensity cardio, and pyramid training is where its at.
MK5 2005 GTI, BLACK, 3 DR, 18" MONZA II, XENONS
Offline emery1990
Re: weight lifting
« Reply #45 on: 18 September 2011, 14:52 »
As said technique is a big factor, I don't do arms no more as I think I get enough work out for them doing my other main groups, my arms always give in before say my chest if doing a bench press. But yer I had a sh!t techinique doing bicep curls, used to turn my wrists at the end to lift it higher, now from my elbow down is pretty much f'd up! Golfers elbow in both arms, tendinitis in both wrists and the tighest top of the forearms the physio has felt lol
can still go up the gym though, but work requiring grip alot, my wrists hurt 24/7. 8 months to fully heal they rekon..kushd.
Offline matg340
Re: weight lifting
« Reply #46 on: 18 September 2011, 16:09 »
Ive seen so many different routine,s advice lately that i think its a case of whatever works for you ?
Gonna stick with the routine i was doing before but drop some of the cardio and improve my diet alot , as it seems to have been working quite well so far :)
Cheers folks
Offline danny_p
Re: weight lifting
« Reply #47 on: 18 September 2011, 16:48 »
never been in a gym but the type of excersise / work you do defanty has a massive effect
if i've been forgeing stuff where your on the hammer all day beating the f**k out of a bit of metal that gives you some serious stammina but your arms don't get big unless your useing really big hammers.
bumping big bits of steel about by hand soon makes you stronger dosent do anything for the stamina tho.
and if you want to make your legs strong there is allways the BBC  boc bottel challenge,     size W boc bottel on your sholder and see how many flights of stairs you can go,  it's fecking hard but i think it's more to do with the awkwardness of the bottl rather than it's weight
all the VW's have gone bar 1.
Offline justalex81
Re: weight lifting
« Reply #48 on: 18 September 2011, 16:51 »
fastest route to a wheelchair i've ever heard!
Re: weight lifting
« Reply #49 on: 18 September 2011, 17:33 »
he can do it in the house, he already has the weights, all he needs in a chin up bar.. Unless you are totally committed a gym membership is pointless...
I am in Afghan at the moment, 4 months is plenty enough time to get a decent shape...Everyone knows the OP is only after a "pretty body"... otherwise he would have already done all of his reading from other related websites and not a car forum
Bumper Vents :D
