Author Topic: weight lifting  (Read 6229 times)
Offline matg340
weight lifting
« on: 15 September 2011, 18:54 »
How do ,,
Anyone on here into weight training ? reason i ask is that after serching the web for advice on routine,s ect ect
There must be a million different routine,s and loads of conflicting advice which tbh is quite confusing lol
Just after some advice on a good routine, diet tips and a good supplement to recommend or which to avoid .
Any info is as always very appreciated peeps
Cheers Mat
preserve wildlife.......PICKLE A SQUIRREL !!!!!!!!!!!!
Offline justalex81
Re: weight lifting
« Reply #1 on: 15 September 2011, 18:57 »
depends on what you're looking to achieve. do you want to be strong or look strong?
Offline bricey
  • One of a few with a PROPER engine
Re: weight lifting
« Reply #2 on: 15 September 2011, 18:59 »
weight lifting/power lifting or body building ?????
DOLPHIN TRAINER
Offline bricey
Re: weight lifting
« Reply #3 on: 15 September 2011, 19:00 »
what i can say is (which may not be up your street)is that steriods do work if you have a slim/lean frame like myself
DOLPHIN TRAINER
Offline Tazzy
Re: weight lifting
« Reply #4 on: 15 September 2011, 19:02 »
if your skinny, hit that fat shakes before the protein shakes, you cant build on whats not there
If It Comes Off, Modify It!
Offline tshirt2k
  • Been there...Done that...
Re: weight lifting
« Reply #5 on: 15 September 2011, 19:04 »
They also make you fill with water, and cover your skin in boils and white heads.  :sick: And seriously affect your endocrine system especially if you are under 25.
Do some research and don't folow routines in flex magazine and the like. Those guys are seriously chemically enhanced and can build muscle taking a sh*t.
Sort your diet out and do simple compound exercises that work a few muscles at a time. Get yourself a book called "strenght training anatomy" it shows you exercises and how to do them properly.
Try to do at least 3 days and split the body parts into 2 parts a day.
« Last Edit: 15 September 2011, 19:11 by tshirt2k »
Mk3 ABF 16VT Megasquirt V3
Offline R32UK
Re: weight lifting
« Reply #6 on: 15 September 2011, 19:08 »
rule no1 dont f**k with steroids esp if you dont know what you are doing with weights. If you want size, lift heavy increase carb intake (in short).
find a routine and stick to it for a 6 wk cycle then check progress.
Offline Uruk Hai
Re: weight lifting
« Reply #7 on: 15 September 2011, 19:08 »
Funny you should say that, we've not long sent a bloke to Crown court for dealing that sh!t !
I disagree, if your skinny you need protein and fluid to build muscle and building on "whats not there" is exactly what you will do with a good diet and a good work out plan !
Offline JC
  • Back in the North.
Re: weight lifting
« Reply #8 on: 15 September 2011, 19:10 »
I get out of bed every day, does that counts  :grin:
Offline bricey
Re: weight lifting
« Reply #9 on: 15 September 2011, 19:11 »
never heard of boils but the rest is true oh and the liver failure etc etc
i used them about 5 years ago as im 6ft4 weigh 12.5 stone,they were a last resort as i was fustrated in not gainging weight/muscle after 2years of traing
DOLPHIN TRAINER
