Author Topic: vag com problem codes  (Read 1265 times)
Offline Richie_C
« on: 14 September 2011, 09:11 »
Just bought one of those cheap vag com units off ebay. Just scanned the car and got 3 codes 1 i was expecting in an abs sensor (rear right). The others iam not to sure on
00519 - MAP sensor - out of range - g71
             - MAP sensor - volatage low - g71
             - MAP sensor - volatage high - g71
00532 - transmission control module relay-supply    Voltage (B+)  malfunction low battery or      bad ground
Does anyone know what those mean?
Cheers guys
Offline danmusic24
Re: vag com problem codes
« Reply #1 on: 14 September 2011, 11:00 »
try google...
ross tech fault codes :smiley:
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 14 September 2011, 12:34 »
00532 only applies to auto's
Offline Richie_C
« Reply #3 on: 14 September 2011, 13:14 »
Abit of research done and 00532 can happen if the battery has been disconected so cleared and all is good 00519 can occur if the vac pipe to the ecu has corroded or blocked so new vac pipes have been ordered
