Author Topic: Temperature gauge/ stiff clutch pedal  (Read 2413 times)
Offline Golfmadsi
« on: 12 September 2011, 23:32 »
I have a Tdi 115. recently bought this an noticed the temperature gauge drops to cold when engine is at normal running  temparature, an the goes up an down, is this due to a faulty sender ?,
Also the clutch pedal feels stiff, has any of you dubbers out there had these problems or know a solution? thx guys.
Offline tdi_blu
  • Golf Gti & T4 2.5 tdi
Re: Temperature gauge/ stiff clutch pedal
« Reply #1 on: 17 September 2011, 01:01 »
Try a new Tempreture sensor in it first make sure you buy a genuine one there not expensive.If that dont sort it replace the thermostat again there cheap and pretty easy to replace in my case I had to replace the 2 but the tempretures perfect now sits on 90.Not sure on the clutch pedel though try googling it  :wink:
Golf Gti
Offline NoCrap
« Reply #2 on: 17 September 2011, 07:45 »
definitely change the temp sensor - you can do this with a full coolant system if you're quick... careful if it's hot though.
give the clutch a bleed to see if that helps, although the cylinder might be failing
