Author Topic: Mk2 fuel pump emergency  (Read 1599 times)
Offline Benrevs
« on: 10 September 2011, 18:08 »
Sorry for double posting!!  My main pump under the car failed yesterday and I am desperate to get the car working for monday morning.  I have got a mk2 16v kr pump from a friend, I know there are some differences as to the pressure system and connections but I can get around that.  My main concern is about the size of the motor/pump... Will it cause any problems having a bigger motor pumping the fuel?? Cheers.
Offline tsr_adi
Re: Mk2 fuel pump emergency
« Reply #1 on: 11 September 2011, 22:49 »
What makes you think its failed? Is it doing absolutely nothing? Checked you have 12v going to the pump when the ignition is on? I had a 16v once that I thought had a duff main pump, turned out the sieve on the lift pump in the tank had a bit of crap in it, cleaned out and all was good again!
Offline Benrevs
« Reply #2 on: 12 September 2011, 19:07 »
Trust me the pump was fubered! I got the 16v pump to work/fit by removing the unneeded extras etc. So all is good thanks.
« Reply #3 on: 17 September 2011, 21:56 »
I think the only difference is higher pressure on the 16v.
