Author Topic: MK3 Cutting Out and VAG-COM  (Read 1464 times)
Offline Ris-gti
« on: 10 September 2011, 07:19 »
everyone on here talks about VAG-COM. i have a mk3 2.0 git 8v and have downloaded the software and have the cable to connect but for some reason i can connect to the car. Any ideas.
i want it to check the car as it keep cutting out every 2 mins when idle. i have changed the coil pack, the leads, distrubutor. but since then (about a hour ago after RAC said that was the problem)but it cuts out more often now with the new coil. plug the old one back in and it last 5-10 mins on idle.
it's doing my bloody head in someone please help
Offline Andy-H
Re: MK3 Cutting Out and VAG-COM
« Reply #1 on: 10 September 2011, 07:39 »
What year is the car?? earlier models had an ISV. Does the car drive OK?? is it just when the car is cold??
'02 A4 Quattro sport - gone
'91 Tornado red Mk2
Offline dom
  • Back in a Mk4
« Reply #2 on: 10 September 2011, 09:02 »
Vagcom can be a pain to get working at times. You need to make sure you've use the right com port.
Where in the country are you? Someone maybe nearby & able to help :smiley:
Offline Ris-gti
« Reply #3 on: 10 September 2011, 09:16 »
year of car is 98. it use to run ok then about 5 mins in to a journey it would cut out, but start again staright away but now the car just starts and the cuts out straight away.
i'll have to keep trying vag-com and the ports then till i get the right one. i'm in the UK.
Offline dom
  • Back in a Mk4
« Reply #4 on: 10 September 2011, 09:40 »
No sh!t :rolleyes:
Offline Ris-gti
« Reply #5 on: 10 September 2011, 09:55 »
Sorry read that wrong. I'm in Essex.
Offline Ris-gti
« Reply #6 on: 10 September 2011, 11:21 »
changed relay 30 now and all seams to be fine. i also got vag-com working but it is only a lite version and can not clear the codes.
one of the codes was about t/b position
