Golf mk3
hardmonkeys
random question?
Topic: random question? (Read 1455 times)
murraymint
random question?
09 September 2011, 21:19 »
tonight i noticed if the ignition is off and the key is out, the brake lights still come on if i put my foot on the brake pedal,
is this normal??
josh
95 Mk3 golf 1.6 CL
96 Mk3 golf gti 16v
89 Mk2 Jetta GL
97 Mk3 golf gti 16v
99 bora 2ltr se
Seanl
Re: random question?
09 September 2011, 21:32 »
No, should only come on at second position on the ignition. No idea what would cause it though, sorry!
Dan_GTi8v
09 September 2011, 22:16 »
mines always done this as well, dunno why but never really cared about it so didnt investigate
Build thread
http://www.golfgtiforum.co.uk/index.php?topic=167291.0
Seanl
09 September 2011, 22:22 »
Probs an earth somewhere that is supplying power direct from your battery rather than through your ignition when switched off. Dunno which one it will be but no doubt something along these lines. Only other suggestion is your ignition switch not turning off properly. Does your steering lock engage?
vwscottie
GTI forum regular
09 September 2011, 22:49 »
Its normal for the brake lights do come on without the ignition on as far as i know all cars do this
Bellend
09 September 2011, 23:04 »
Some cars do, some don't.
Volkswagens do. Sean, yours will.
Fords don't.
Where all my moneys went.
Seanl
Reply #6 on:
09 September 2011, 23:12 »
I beg to differ! Tried mine yesterday as I have a little rust bubbling just under the rear n/s light. Took it off to have a look how bad it was, and after putting it back on and connecting up, I had to turn ignition to second position to get the lights working.
Bellend
Reply #7 on:
09 September 2011, 23:43 »
Something wrong with yours then.
Got an aftermarket alarm or something?
All four of my MK3's and both my dads T4 and VW LT with the same era of electrics all do it. As did works MK4.
mwep201081
Here all the time
Reply #8 on:
10 September 2011, 02:03 »
don't quote me but I believe reverse lights are the same too?
Seanl
Reply #9 on:
10 September 2011, 08:13 »
Ok I've just been out to check, and I appologise for my smugness, and I stand corrected. :embarassed:
Brake lights, and side lights come on without the need for the key to be in place. Reverse lights do not though.
Golf mk3
hardmonkeys
random question?
