Author Topic: Help - What have I done to my dashboard illumination...  (Read 1408 times)
Offline vRS_Si
« on: 09 September 2011, 18:39 »
This afternoon I replaced some dash bulbs.
I changed the bulb in the headlight switch which had blown.
I tested afterwards and all worked well.
Next was the heater panel bulb, I swapped this over and then put the dash back together.
But this time when I turned the ignition on I now have no dash illumination at all!!
All the switches and the speedo/dials are in darkness.
I checked fuse 21 - dash lights and this was fine.
Any other ideas?
Offline trog_nfs
Re: Help - What have I done to my dashboard illumination...
« Reply #1 on: 09 September 2011, 18:40 »
Knocked the dimmer switch? Wouldn't be the first! :lipsrsealed:
Offline vRS_Si
« Reply #2 on: 09 September 2011, 18:43 »
Lol, no dimmer switch is set to max brightness... :sad:
Offline vRS_Si
« Reply #3 on: 09 September 2011, 18:54 »
I've also noticed that when I turn the headlight switch to on the Hazard light button lights up for a fraction of a second before going out again...
Offline vRS_Si
« Reply #4 on: 09 September 2011, 19:42 »
Now fixed!
Wel sort of...
It appears that VW sold me the wrong or a duff bulb (certainly the new and old bulbs look the same) for the heater dials that must have been tripping everything else out when I turned the headlights on.
Offline Dan_GTi8v
« Reply #5 on: 09 September 2011, 20:58 »
so you just changed the bulb? I have a similar problem on mine but as I also got smoke from the dash (which is now fixed) I assumed I'd shorted something out
Offline stainesy
« Reply #6 on: 09 September 2011, 23:28 »
my heater pannel lights just stopped working a few months ago so i just carboned all of it lol. needs the chrome knobs though.
got the locations of dials memorised lol.
sorry for bad picture.
Offline Dan_GTi8v
« Reply #7 on: 10 September 2011, 16:48 »
chrome knobs are never needed :P
Offline vRS_Si
« Reply #8 on: 11 September 2011, 16:24 »
Yep, I'd just changed the bulb.
I took the new bulb out and replaced with the blown origninal bulb, re-tested and all the dash lights came back (except for the heater obviosuly...).
