Author Topic: Quick help!  (Read 852 times)
Offline kempie
  • where would we be without duct tape?
Quick help!
« on: 09 September 2011, 15:06 »
got my MOT on monday and the handbrake needs tightening, where is the ajuster? and how do i acess it?
thanks guys x
Offline dragongreengolfgti
  • my golf gti mk3
Re: Quick help!
« Reply #1 on: 09 September 2011, 15:18 »
Best bet is mate take your back wheels off check the calipers over and make sure there not seized first take them apart really easy to do  :smiley: clean them up and copper grease them up and put them back together so long as there operating ok thats all you will need to do. However if you fancy adjusting the cables the adjuster is under the back ashtray assembly and handbrake cover 8 or 10 mm bolts on end of the cable but i can gaurantee this wont need to be adjusted inless the cables are shot. And i can bet you over winter there will be endless amount of threads on here saying my handbrakes sticking on when it freezes over night reason being is the moisture freezes inside the cable casing and the handbrake wont work or stay stuck on not good feeling when late for work  :laugh: if they look old i'd replace them now there about £14 a side and take about half hour to replace and new ones dont freeze  :smiley: hope some of this helps  :smiley:
Offline Screech16v
  • MK3 20vt AGU
Re: Quick help!
« Reply #2 on: 10 September 2011, 14:16 »
I had the frozen handbreak issue last winter ,reversed out of the drive not even noticeing,pulled off down the road  wahaa 180 on the first corner without even trying  :evil:
