Author Topic: power to speedo dials but speedo doesnt registor speed?  (Read 1127 times)
Offline mani12354
 :sad:
Hi all, i get power to the dials on the dashboard but the the dials are off but when i acclerate hard in first then break it works fine what could this be please help!
Offline gasketface
Re: power to speedo dials but speedo doesnt registor speed?
« Reply #1 on: 09 September 2011, 14:32 »
Sounds like you have a bad connection somewhere  :smiley:
Offline mani12354
« Reply #2 on: 09 September 2011, 15:06 »
 :shocked: where doh!
Offline Seanl
« Reply #3 on: 09 September 2011, 15:36 »
Have a look at the back of the clocks. Take the shroud off surrounding them, and blanks on the left, and lighting switch on the right. Undo the screws, pivot it forward and pull it out. Simples!
Offline mani12354
« Reply #4 on: 10 September 2011, 09:06 »
that cant be right :O cos ive never touched it the car was siting there for like 3 weeks and before it was perfect
Offline Seanl
« Reply #5 on: 10 September 2011, 09:15 »
It'll take 2 minutes to remove and have a look. Wires/connectors can work loose over time, in a car that vibrates etc. Doesnt matter if you have not checked it. If you wanna try and source the problem, check it out. Its not only an MOT failure remember, its illegal, but mostly its dangerous.  :wink:
