Author Topic: knocking from drivers front wheel well after fitting coilovers!  (Read 7184 times)
Offline DanChave
Trackrod end? If so what is the cheapest/best place to get them? I haven't had the car tracked yet...........
Offline Len
Re: knocking from drivers front wheel well after fitting coilovers!
« Reply #1 on: 08 September 2011, 14:14 »
Did you fit new tops mounts as per all the advise on here?
www.sas.org.uk
www.the-ace.org.uk
Offline DanChave
« Reply #2 on: 08 September 2011, 14:19 »
Nah, they were all fine!
Offline Len
« Reply #3 on: 08 September 2011, 14:38 »
Well fine or not that is most likely your problem! :rolleyes:
www.sas.org.uk
www.the-ace.org.uk
Offline DanChave
« Reply #4 on: 08 September 2011, 17:45 »
When I fitted the new coilovers there were no play in any oft them :/ I will check again though!
Offline Len
« Reply #5 on: 09 September 2011, 08:43 »
Look it is false economy to not change the mounts when you fit coilies!
You may think the existing ones are fine but you are placing additional stresses on them. Do you know how old they are?
www.sas.org.uk
www.the-ace.org.uk
Offline DanChave
« Reply #6 on: 09 September 2011, 11:34 »
They were fitted for last MOT so I thought they would be fine lol!hmf turns out one of the top mounts was not as tight as it could be. I drove round for a good hour and the mocking has gone! Result!
