Author Topic: interior/ seats  (Read 4100 times)
Offline steble
interior/ seats
« on: 07 September 2011, 22:49 »
anybody know what seats fit mk1 cabby's easily?
Offline SoundillusioN
Re: interior/ seats
« Reply #1 on: 08 September 2011, 08:53 »
mk1, mk2, scirocco and corrado front seats all fit, as do height adjustible polo mk3.  mk3 seats fit if you swap over the old cabby seat base frame also.
the slider issue depends on the age of the cabby, in about 84ish they changed to the MK2 side which means later seats are a direct fitr, if its earlier than that then only mk1 items are a direct fit.  either way if you fit the wrong type seat the only issue is the slider wont work, you may also be able to swap the cabby fdrame over to the new seat dependign on what it is. if its a pre-90 mk2 or MK3 polo then the frame should swap, cabby frames wont fit post 90 mk2 seats or scirocco/corrado.
another option is to swap over the slider handle, easy with a little trickery under the seat. however if the height adjust handle is on the front this wont work as the handle is where you want the slide lever to be!  You can get height adjust bases with the handle on the side though, these are perfect for the swap trick.
Offline steble
Re: interior/ seats
« Reply #2 on: 09 September 2011, 07:44 »
Awesome info cheers :) mines a later cabby too :)
I was wondering which back seats fit though as these will be more difficult if they are different sizes wont they.
Re: interior/ seats
« Reply #3 on: 09 September 2011, 09:36 »
Very difficult... For example, a popular-ish conversion for a mk1 tintop is putting the rear bench in from a corrado, look great but need a lot of work.
http://www.matey-matey.com/corrado_seat_conversion.shtml
For a cabby its even worse, in fact almost impossible I think due strengthening metal work between the bench and the boot.  Better off leaving the original in and getting it re trimmed to match whatever you put up front to be honest.
Offline Guy
Re: interior/ seats
« Reply #4 on: 09 September 2011, 09:58 »
i do know of a semi-decent corrado interior going spare
Re: interior/ seats
« Reply #5 on: 09 September 2011, 10:12 »
Quote from: rubjonny
its not an easy job at all, it needs a lot of hacking to the bench to get it in. the problem is that metal bar under the rear seats, the corrado seat backs are far too tall to fit nice and need cutting down. better off just leaving the old bench in and either moulding in some headrests or adding some mk2/3 ones
Offline jimmyshaw1980
Re: interior/ seats
« Reply #6 on: 22 September 2011, 15:47 »
have some mk3 ones?
Re: interior/ seats
« Reply #7 on: 22 September 2011, 23:32 »
Better to keep the standard rear bench in a cabrio tbh.
Offline steble
Re: interior/ seats
« Reply #8 on: 23 September 2011, 19:27 »
interested :D sorry only just spotted this lol
