Author Topic: Brake servo piping / plastic tubing  (Read 2224 times)
« on: 07 September 2011, 21:52 »
Go home earlier and could hear a noise.
Had a look under the bonnet and the pipe from the brake servo to inlet manifold was cracked.
Quick question does this need to be a hard plastic pipe, I have replaced it with 8mm fuel hose (high pressure) as Skoda cannot supply a delivery date for a new pipe.
 :undecided:
Offline AudiA8Quattro
Re: Brake servo piping / plastic tubing
« Reply #1 on: 08 September 2011, 00:01 »
What is the internal diameter of the plastic pipe?
I would expect the rubber hose to fine as a temporary measure.
« Reply #2 on: 08 September 2011, 00:06 »
8mm as that is the size of the fuel pipe that fits all ok, not sure if the plastic hose is a fraction smaller.
« Reply #3 on: 08 September 2011, 00:08 »
Try fitting it, and then test the brakes thoroughly  :grin:
« Reply #4 on: 08 September 2011, 00:11 »
It is fitted and have done 40miles all ok, not sure if that is good or bad.
« Reply #5 on: 08 September 2011, 09:35 »
Probably ok then.
The only problem i can see is when the rubber hose gets older it might collapse internally, leading to a loss of brakes.
That won't happen for years though.
« Reply #6 on: 09 September 2011, 00:06 »
Well Skoda have tracked one down, need to collect in the morning.
« Reply #7 on: 09 September 2011, 11:09 »
Cool  :smiley:
« Reply #8 on: 11 September 2011, 21:35 »
Cool  :smiley:
Turned out to be the wrong pipe, looks like it is modified now into 3 parts and one part is no longer available.
So the hunt is on for a s/h one.
