Golf mk2
Alarm draining battery
Topic: Alarm draining battery (Read 2420 times)
sKrEwBaLL
Here all the time
17 September 2003, 13:11 »
Hi
If I leave my alarm on for more than a couple of days, when I go back to the car, the battery is completely flat (the battery is fairly new). Any ideas why this is happening..??
Neil
golfvr6
Guest
Re:Alarm draining battery
17 September 2003, 13:29 »
Something wrong with the alarm i guess. Try a specialist.
Dizzie
Forum addict
Make friends with your fast
17 September 2003, 14:10 »
if it doesn't happen then you leave the car without the alarm on then yes, it must be the alarm.
Mk2 Golf GTi restoration -
https://youtu.be/s-Jj5bABxM8
GTI16vGaz
GTI forum regular
New car will be displayed soon.
17 September 2003, 16:11 »
There should be a back up battery that the alarm use's, maybe if this is flat its using the main (car) battery to keep you car alarmed.
or again, the alarm could be faulty and need replacing.
What alarm is it? and model?
Garry
modulater
21 September 2003, 12:48 »
It sounds like the alarm is draining your battery. Iwould have the battery checked out just to make sure and go from there. A lot of alarms have power feeds out for electric window closing etc and one of these may be shorting out causing battery drain.
Get it looked over properly
Golf mk2
