Author Topic: help with maf readings?  (Read 2308 times)
Offline smythe
« on: 07 September 2011, 20:22 »
i found a wire off my maf after alot of mucking about after getting 0.00g readings
now the wire is  back in and awaiting replacement plug from vw.
here is what i got
at idle 52.17 gs
at under load @ 5000 rpm  260 gs
i could not do a full 4rd gear test as i ran out of road & weather was dismall
do these reading look normal ? high or low ?
forgot to add mk4 v5 170  :grin:
cheers smythe
« Last Edit: 07 September 2011, 20:30 by smythe »
Offline Yohan
Re: help with maf readings?
« Reply #1 on: 12 September 2011, 14:33 »
They look high to me.
I may be wrong due to my engine having a turbo but on idle I think mine sit around 3.0 g/s and peak about 168.0 g/s.
168 x 1.25 = 210bhp using the rough rule of thumb. So spot on for a 1.8T AMK.
260.0 g/s x 1.25 = 325bhp :shocked:
Offline smythe
« Reply #2 on: 15 September 2011, 00:27 »
Don't no why but this has all changed like its bedded in since i fixed the broken wire
sits about 2.75gs
and im the mid hundreds at redline ! (lost the log)
so hopefully running about right!
s
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #3 on: 15 September 2011, 08:34 »
219 -222g/s now.... :wink:
 01455 617233
