Author Topic: Lambda Issue  (Read 908 times)
Offline WadGTI
  • Golf GTI'er
Lambda Issue
« on: 07 September 2011, 20:07 »
Hi folks,
Decided to run vagcom on the golf tonight as I noticed it has been rather thirsty recently. I will admit the exhaust system from manifold to backbox is in pretty poor condition and is being replaced asap.
VAGCOM picked up -
v00537 - Lambda (Oxygen Sensor) Regulation
            18-10 - Upper Limit - Intermittent
I noticed the other night after giving the car a good roasting an eggy smell and made me think the cat is on the way out, but the smell has never came back.
Other dranking a bit too much fuel and blowing underneath the driver seat, the car is running fine, no idle or running problems.
Am I correct i n saying the poor condition of th exhuast system is probaly throwing the lambda off.
Thanks
Offline WadGTI
  • Golf GTI'er
Re: Lambda Issue
« Reply #1 on: 07 September 2011, 20:11 »
Also, it picked up the
00513 - Engine Speed Sensor (G28)
            16-10 - Signal Outside Specifications - Intermittent
I think this is the crank sensor?? If so, it was replaced recently, and I have no issues with the engine starting up or rev counters going mad. I am thinking it could be an old code before the crank was changed and should just clear the code
