Author Topic: Top Mounts  (Read 2211 times)
billabong
Top Mounts
« on: 07 September 2011, 13:24 »
Ok, I think my top mounts need replacing.
I've been looking at my options:
Volksbits twin pack of Bearing + Topmount (£20).
OR
2 x 1J0412249 - Bearing (£6.41 each)
2 x 357412331A - Top mount (£13.80 each)
Totalling just over £40.
Is it worth paying twice as much for the OEM parts?
Ta
W
Offline boneybradley
  • Back in a Mk3...
Re: Top Mounts
« Reply #1 on: 07 September 2011, 13:26 »
search for febi (which these may be?) and a worthwhile upgrade are vr6 spec mounts if running lower (proper one's not like listed on ebay etc)
Offline Dan_GTi8v
Re: Top Mounts
« Reply #2 on: 07 September 2011, 13:30 »
http://www.ebay.co.uk/itm/VW-GOLF-MK3-GTI-VR6-CORRADO-SHOCK-TOP-MOUNT-KITS-C358-/200429674666?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2eaa8a20aa
£13.95 + £5.65 postage. Tierod69 is an awesome seller for vw parts, cheap as chips and always oem or better quality
these oens are febi if I remember rightly, fitted them to mine a while ago with 40mm lowering and I drive pretty hard, still going as good as new
billabong
Re: Top Mounts
« Reply #3 on: 07 September 2011, 21:11 »
Ordered, cheers Dan :)
  • Back in a Mk3...
Re: Top Mounts
« Reply #4 on: 07 September 2011, 21:13 »
b.t.w them from tierod are non vr6 spec mounts (they all fit the same, so they are listed fine but there not heavier duty)
Offline Khare
  • The bear that khares
Re: Top Mounts
« Reply #5 on: 07 September 2011, 21:16 »
Which ones are heavy duty then? I'm in need of new top mounts.
  • Back in a Mk3...
Re: Top Mounts
« Reply #6 on: 07 September 2011, 21:20 »
I had the febi number as I bought the vr6 one's (when I had my old golf)
check febi.com (or similar) :wink:
Offline Dan_GTi8v
Re: Top Mounts
« Reply #7 on: 07 September 2011, 22:46 »
the Tierod ones are VR6 ones aswell, afaik they stopped making seperate ones for vr6 and just made them one type fits all (unless I just made that up but I'm sure I heard it somewhere :P)
I replaced my old vr6 spec ones with these and they seem exactly the same tbh, though I'm not really sure whats different on the vr6 ones? But I got a 1.8t lump in mine and they are doing fine so far  :smiley:
« Last Edit: 07 September 2011, 22:48 by Dan_GTi8v »
VW BUSH
Re: Top Mounts
« Reply #8 on: 07 September 2011, 22:51 »
I think VW still sell VR spec ones, the febi ones I bought were one size fits all although this was at ecp so maybe a pat part thing.
VW ones cost a bomb, try gsf or a good VW supplier for VR spec or uprated items :smiley:
  • Back in a Mk3...
Re: Top Mounts
« Reply #9 on: 07 September 2011, 22:54 »
all mk3 top mounts fit all models...but febi do make a specific h/d vr6 set up as well
